when making a mid ranged rig, is it preferred to have higher spec ram or a higher spec cpu?
*considering that if the ram or cpu was chosen to have the higher specs, the other would have lower*
For example, would you rather have:
-16gb ddr3 ram and i3
or
-8gb ddr3 ram and i7
This isnt for a rig of my own, im just curious
https://linustechtips.com/topic/949008-low-ram-or-low-cpu-specs/
Low RAM and high-end CPU, you can always add more RAM in the future for way cheaper than buying an entirely new CPU.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
