Hey everyone, so I’m currently in the process of building my Pc, my graphics card is the last thing I need to hook up to the power supply. So I have a strix gtx 1080, and on the card itself it has a both a female six pin and female 8 pin. Do I hook up the graphics card to the psu on both sets? So a total of two cables from power supply to graphics card one 6 pin and another 8 pin?
https://linustechtips.com/topic/948968-help-on-installing-graphics-card/
Yes you need both 6 and 8 pin for the card to operate normally.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
Yes, 6 pin and an 8 pin. 2 Cables total from the power supply
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
If you can, yes.
Both definitely need to be connected, but by using separate cables you keep the amount of power flowing over each individual cable lower, which can be useful if your PSU cables are of thin gauge. It means they'll heat up less.
