What else is going into the build? Nice case man!
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1271038
Nice build!
PS: I thought this was a news post abut Corsair starting to sell ice cubes lol.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1271049
  • 2 weeks later...
Since this build is mainly a lot if wooosh go for Windforce cards! The one with the triple fan design!
I also prefer that for your build cause I tend to stick to a brand or two for my builds.
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374334
did some more work on my build!
Installed CPU! Little scary haven't done one for awhile!
post-52337-0-09912100-1389834960_thumb.j
Just gonna use the stock intel cooler for now.... Any suggestions on a better one? Was thinking of going with a Coolermaster Hyper 212 Evo
post-52337-0-30626400-1389835227_thumb.j
It Boots! Front fans look pretty cool too!
post-52337-0-14730900-1389835830_thumb.j
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374398
Nice case (i use it xD Need any help with this case Anything @ all ask me)
Question Did i just see a piece of wood behind the Mother Board ?
Spec: in full if you can get time ...
Have a look @ my build log if you want . you may
be able to get some ideas of it or not .
Case: | TT Core x71 | Mobo: | Gigabyte Aorus Elite DDR4 | Cpu: 13600K | 1.300V | P-Core 5.6GHZ | E-Core 3.9GHZ | Cpu Block: EK Quantum Velocity2 | Ram: Team T-Force Vulcan Z 4x8GB 3200MHz DDR4 | Gpu: Gigabyte GTX G1 970 Bios Hacked 1.275V | Gpu Block: EK | Cooling: Custom Loop | Rads: 4 | PSU: Corsair RM 1000w
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374446
Windforce cooler is loud, go for something like MSi's Twinfrozr or Asus's DCUII. They are both excellent coolers.
@Dielan
Muffinator
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374462
"Just gonna use the stock intel cooler for now.... Any suggestions on a better one? Was thinking of going with a Coolermaster Hyper 212 Evo"
Please don't. :)) Don't ruin this beauty of a rig with a 212...
Something from Noctua but replace the fans? or something from dark Rock.
Better yet are you interested in the Zalman Reserator? (I dont think I spelled it correctly)
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374464
@Dielan
Not so much. I've built rigs with them and they seem ok. Louder but by much.
Also with the amount of fans in his system I dont think he is concerned with how loud the system is. :)
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374474
Yea, I don't mind a bit of fan noise, and probably will go with the windforce just to stick with Gigabyte and I think they look pretty cool too.
What cooler from Noctua would be a good fit for in here? Not a fan of there brown fans.....
If you don't like the color scheme of noctuas, get a dark rock or hyper 212 evo cooler
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374726
Hyper 212 with a couple of Corsairs SP120 Performance fans be alright or would the one of the dark rock ones be better? i haven't really hear of them much.
AF at the back and SP at front.
The dark rock ones are beefier and sleeker looking.
With Noctua one you can get the D-14's and replace the fans. You can NEVER go wrong with noctua
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374933
Thanks, I figured out some of the case soo far removed the 2.5" bays and the 5.25" bays where kinda tricky but i got it.
A piece of wood? Where?
Ill do a full specs later tonight maybe..
Never mind i know what wood is ,in 1 of the pics it looks like wood but it some thing else behind the case it self. Any way ,
Yes those bays can be tricky .Do ya self a favor the hot swap cables take those 4 screws out & remove those cables ,i did that with mine & i tell ya less cables to contend with is great ,plug the power / sata directly in & bobs ya uncle.
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1374992
sp af ? what's that haha doesn't come to mind sorry mate.
https://linustechtips.com/topic/94851-corsair-ice-cube/#findComment-1375014
