I am using a 8700k with Cryorig R1 Universal.
Currently using the Thermal Paste that came with the cooler which is called "CP9"
I have the processor slightly overclocked to 4.6 and was thinking if getting a better thermal paste ( i have Thermal Grizzly Kryonaut in mind) would  make much difference.
I will go for Grizzly if there is significant diff in temps like more than 5 degrees or something.
  • CPU i7-8700k Motherboard Asus ROG Strix z370-F RAM G.Skill Trident Z RGB 8x2 GPU Asus ROG Strix 1070 OC  Case Corsair Crystal 460x RGB Storage Samsung 950 Evo with 9TB HDD PSU Bitfenix Whisper 750W Display(s) Asus VX229H Cooling Corsair hydro h150i Pro RGB Keyboard Corsair k95 Platinum RGB Cherry MX Brown Mouse Logitech G502 Proteus Spectrum  Corsair MM300 Mouse Pad Corsair MM300 Sound JBL LSR 305 + Hyperx Cloud 2+ Focusrite 2i4
https://linustechtips.com/topic/948058-thermal-paste-recommendation/
2 minutes ago, 1kv said:
You should be fine with your current thermal paste. If you want, you can put some Grizzly on but I seriously doubt it'd do much at all.
Ahhh if its not gonna do much then i wont go for it, money is tight at the moment :(
7 minutes ago, 1kv said:
Do you know what your current CPU temps are? If so, please post them here.
Thanks! :)
Well idle temps are between 36-39 with ambient being 30.
At load with AIDA64 temps hit high 70s. and with FPU only crosses 80.
5 minutes ago, 1kv said:
Yeah, that's perfectly fine. You don't need to change your thermal paste.
Yeah temps are okay, but if i could lower it a bit i would push to 4.7 for daily use.
