Hello everyone,
i want to store my project on a external device, i'm not sure if i need a NAS or a smaller server for it.
I will store mainly website projects, images, pages but also videos and clips on it.
About 1TB of storage should be enough for the start and could upgrade it later.
https://linustechtips.com/topic/948052-storage-for-projects/
Depends on what you want to do with your files:
Just store it for cheap and access it with one device? And external hard drive will do you fine.
Access it with multiple devices and throw in a RAID array for good measure? A NAS server will be the better option.
If you decide to go with a NAS, you can either build one yourself or buy a prebuilt unit from synology or the likes online.
75% of what I say is sarcastic
So is the rest probably
https://linustechtips.com/topic/948052-storage-for-projects/#findComment-11539645
The cheapest option would be to buy a 1TB external USB drive and just plug it in.
or go for a nice small NAS if you want. they're not hard to set up.
CPU: AMD 3800X GPU: GTX 1080 Ti RAM: (16GB) 2x Corsair 8gb DDR4 3200Mhz Drives: SanDisk 240GB SSD, Samsung 500GB SSD, WD 1TB HDD
Motherboard: MSI X470 Gaming pro plus PSU: Gigabyte 650 watt Monitor(s): 27 inch AOC 1440p
https://linustechtips.com/topic/948052-storage-for-projects/#findComment-11539664
