Hey guys,
I'm in need of help upgrading the ram on my computer. I have a Dell OptiPlex, the big tower; and I bought RAM to upgrade my work PC from 4GB to 8GB and eventually upgrade it to 16GB. The ram was 2 sticks of DDR3, the recommended type. Each stick 4GB totaling eight. But when I installed the 8GB the computer rejected it and I was forced to go back to the 4 lousy gigs. I'm thinking I either bought a non-compatible version of the DDR3, or it was defective. Links in below of my computer and the RAM I bought. Oh! I should also mention that I troubleshoot the issue before giving up and going back to the original RAM. Please help me get my PC's RAM upgraded.
Computer Model: https://www.newegg.com/Product/Product.aspx?Item=9SIA8WV5MM3588&ignorebbr=1&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-Desktop+PC-_-9SIA8WV5MM3588&gclid=Cj0KCQjwvqbaBRCOARIsAD9s1XAxgjJg2IFBpjjLEQycaHsDOldi3eOW_kqal4hsGF-vA4Z6fqvjNgAaAk4oEALw_wcB&gclsrc=aw.ds
Ram: https://www.amazon.com/gp/product/B004JKNIZQ/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Thanks,
Mike
https://linustechtips.com/topic/947835-ram-problem-need-help/
3 hours ago, kb5zue said:
Maybe the mobo is due a BIOS update to be able to use the 8 gigs?  I clicked on the link for the system and it says use only 1066-1333 ram while the ram you are putting in is 1600.  That could contribute too, maybe........
I agree with you on this; might need to update the BIOS.
As for DRAM frequency, DRAM JEDEC default is usually DDR3-1333 -- I don't think that would be an issue...
59 minutes ago, StarfleetCap said:
Maybe you have a version of windows 32 bit.
The system should not just fail to boot (if that is what the OP is referring to when it "rejects" it).
A 32-bit OS will recognize 8GB, 16GB, or whatever, but will simply say " (4GB usable) ".
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/947835-ram-problem-need-help/#findComment-11536108
