There should be some sort of other plastic or metal mounting hardware that you can use to screw things into . What about the square mounting bracket that came with the board ? What does the manual say (RTFM)?
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
10 minutes ago, SebbeMapster said:
Yeah it does say that but the holes to insert the pump seem to be too big for the included screws.
As @Coaxialgamer said, there should be a bracket that goes behind the motherboard. I suggest watching a video on installation or reading the manual before proceeding. Take minutes to read/watch vs the seconds it could take to fry your chip and board.
