OK, so i recently got a new processor and motherboard and i tried to install the KB2645594 & KB2646060 hotfixes for the FX processors. I installed both of them but then i needed a fresh install of windows 7 becuz it was all bloated etc.. After fresh install i installed all new updates and when i try to install these fixes it says 'this update is not applicable for your computer' What the hell is going on? Help please
CPU: FX-6100
Mobo: Asus M5A78L-M LX V2
Thanks.
| CPU: INTEL i5 6600k @ 4.6Ghz @ 1.328v | Motherboard: ASUS Z170-AR | Ram: G.SKILL 2x8GB 2400Mhz | CPU Cooler : Corsair H100i V2
| GPU: GIGABYTE GTX980Ti G1 GAMING | SSD: SAMSUNG 840 EVO 250GB  Storage: WD 1TB GREEN | OS: Windows 10 Pro 64bit | PSU: FSP 650W AURUM S |
<<<<< BLK-Phant0m >>>>>
https://linustechtips.com/topic/9467-fx-patch-fix-not-working/
Maybe during the fresh installations they were both automatically installed? Just a guess..
Never mind i solved it, apparently the latest win7 patch didnt install.
https://linustechtips.com/topic/9467-fx-patch-fix-not-working/#findComment-103727
