Windows will not boot, I keep getting stop codes
-101  initiation failure
-kmod expectation not handle
-system tread expectation not handled, what failed ntfs sys
-bad pool header
-page fault in non paged area
-system pte misuse
-registry error
-system service expectation, what failed wim fsf sys
-memory management
- 0xc000021a
The  automatic repair is it working and my computer just keeps rebooting to try and fix itself.
My system is a
-20gb ram
-120gb ssd
-1tb hd
-2tb hd
-7970 msi lightning
-asrock z87m extreme 4
intel 4690k at 3.5ghz with stock cooler
https://linustechtips.com/topic/946627-please-help/
Reinstall Windows. If that doesn't fix it, start running stress tests and hardware diagnostics to see if you can narrow down the problem to a piece of hardware.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/946627-please-help/#findComment-11524472
