I have a hyperxcloud 2 headset - which I have been using for gaming. I noticed it isn't detected in Realtek, which is understandable as it is usb plugged. Should I use the usb or an adapter like this - Sound Blaster Audio/Mic Splitter which I have recently got my hands on - brother bought it for some reason then gave it to me when he didn't need it. I tested it out for a mic - sounds worse than the usb plugin with the controller - question is will it make it easier to hear footsteps etc on games like Rainbow Six Siege?
https://linustechtips.com/topic/946261-hyperxcloud-ii-help/
The usb dongle they give you with the cloud 2's is crap, use your cable
https://linustechtips.com/topic/946261-hyperxcloud-ii-help/#findComment-11520851
Any ideas on how to set it up in realtek and sound studio if needed? Im on a rog mobo so can use those features if needed. Been testing it out and to me it seems like the dongle sounds better - and the mic is much better with the dongle.
https://linustechtips.com/topic/946261-hyperxcloud-ii-help/#findComment-11520856
