Posted July 10, 2018 Hearing a ticking noise in headset, looking for a way to fix it. Thanks! Link to comment https://linustechtips.com/topic/946087-tickinginterference-sound-in-headset/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 10, 2018 If you are using front panel to connect headset, try using back ones. We also need more information if you really want find root of the cause. You should also do some basic troubleshooting to rule out broken components. Magical Pineapples
