So
I have weird audio issues, so for some reason discord/mumble/audacity cannot received any audio input.
The microphone is working fine because I have tested on many machines and also systems "listen" function shows it should be working because you are able to hear microphone input.
Thing I have tired:
Switching to front io microphone.
Used a different microphone
Test microphone on a different machine (Working)
Used Listen function under microphone and was able to hear my own echo/voice
Tired 2 different audio drivers versions
Reinstall Audio drivers
Important Specs:
Motherboard: Sabertooth Z170 Mark 1
Mic: Vmoda Boom Mic Pro
Magical Pineapples
https://linustechtips.com/topic/945262-werid-audio-issues/
11 minutes ago, Timotheus2 said:
Windows Settings > Privacy > Microphone > Allow apps to use it
Already enabled.
Magical Pineapples
https://linustechtips.com/topic/945262-werid-audio-issues/#findComment-11511948
