hi,
My name is Arvind from India
i want to buid a supercomputer for my video editing, 3d rendering and simulations. i am using 3D maya,Clarisse,Houdini,Mantra,Octane,V-ray,Arnold,Red shift,Nuke,After Effects,Premiere Pro,Mari,Substance Painter / Designer. I bought some parts but some are remaining plz give me solution to choose correct hardwere for this Machine.
CPU- Intel Xeon  W-2155 Skylake 3.3GHz (4.5GHz TB) 140W 13.75MB L3 (10 Cores / 20 Threads)
GPU- NVIDIA Quadro P4000 5GB GDDR5 PCIe 3.0 x16 Workstation Video Card
MotherBoaed -  ASUS WS C422 PRO/SE Socket R4 (LGA 2066) Intel Xeon W, Workstation Motherboard
Memory-Samsung 32GB (4 x 8GB) 288-Pin DDR4 2666 (PC4-21300) ECC Server Memory
https://linustechtips.com/topic/945039-build-hardcore-system/
Does your motherboard have NVME and how much USD are u willing to spend?
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/945039-build-hardcore-system/#findComment-11509973
CPU Cooler: NZXT - Kraken X72 Liquid CPU Cooler  ($207.99 @ Amazon)
Storage: Samsung - 960 EVO 1TB M.2-2280 Solid State Drive  ($422.49 @ Amazon)
Case: Corsair - Air 740 ATX Full Tower Case  ($139.99 @ Amazon)
Power Supply: be quiet! - DARK POWER PRO 11 750W 80+ Platinum Certified Semi-Modular ATX Power Supply  ($618.10 @ Amazon)
Total: $1811.06
Generated by PCPartPicker 2018-07-06 15:01 EDT-0400
There's what you're missing. Enjoy.
https://linustechtips.com/topic/945039-build-hardcore-system/#findComment-11510001
1 minute ago, Arvind Kachare said:
no NVME on motherboard     and about 5000 USD
Saw on another site that you do have NVME, however that could be a different variant. What drive connections do you use, SATA?
https://linustechtips.com/topic/945039-build-hardcore-system/#findComment-11510008
Well here's an updated list since you don't have NVME:
Storage: Samsung - 860 Pro 4TB 2.5" Solid State Drive  ($1699.99 @ Amazon)
Total: $4366.06
Generated by PCPartPicker 2018-07-06 15:07 EDT-0400
https://linustechtips.com/topic/945039-build-hardcore-system/#findComment-11510017
whats the advantage of NVME
Miles faster than SATA.
https://linustechtips.com/topic/945039-build-hardcore-system/#findComment-11510022
can you suggest me any motherboard
I'll see if there are any NVME compatible LGA2066 boards for you.
https://linustechtips.com/topic/945039-build-hardcore-system/#findComment-11510033
Well I found you a board with NVME support so here's my original build with a new board for you:
Motherboard: Asus - STRIX X299-E GAMING ATX LGA2066 Motherboard  ($305.00 @ Amazon)
Total: $2116.06
Generated by PCPartPicker 2018-07-06 15:15 EDT-0400
https://linustechtips.com/topic/945039-build-hardcore-system/#findComment-11510044
