So I noticed whenever id use Safari an as would open so I did a Malwarebytes scan on my.pgone and it detected android/adware.mobidash.nc but when I would press remove it would say removal unseccsesful and tell me to manually remove it but I have no idea how it go onto my phone. Help!
I'm using an LG v30 with Android 8
Tysm!
https://linustechtips.com/topic/944861-androidadwaremobidashnc-help/
Tysm!
Malwarebytes Android is used to identify malicious apps, not uninstall them. You'll need to go into your settings and manually uninstall from Internal Storage > Apps. MobiDash often comes in the form of Punch Club, but may be under a different name in your case. If the ads that Mobidash generates are still appearing, you will need to clear your cache under Internal Storage > Cached data and restart.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
I've uninstalled like every single application I've installed recently and cleared cache and ads are still there.
Edit: clears cache again and haven't gotten an ad yet. Crossing my fingers
Thank  you for the help!
Update 2: it didn't fix xD the ads are still there xD
If you can't find which app is causing the problem, it probably gave itself admin privileges after being installed. Apps with admin privileges can hide from view while remaining operational. You can revoke this privilege by going under Security > Advanced > Device admin apps.
Desktop
Homelab
That worked!! Thank you so much!!!
