I'll be getting an iPhone 6s soon and intend to charge it at my computer a lot (using an amazon basics lighting to usb cable) and am wondering if this will be as fast as the charger that comes with it. If I remember correctly the amperage of the stock charger is 1.0 amp and I believe usb 3.0 can deliver a maximum of 0.9 amps but in practice this may not make much of a difference in charging speed. Can anyone with experience confirm or deny this?
PC Specs:
CPU: AMD 1700x Cooler: Corsair H100i V2 Motherboard: Asus Crosshair VI Hero RAM: 4 * 8GB G.Skill RGB DDR4 Graphics: EVGA GTX 1080 Ti SC2 Storage: Samsung 960 EVO 500GB Case: Fractal Design Meshify C PSU: EVGA 750w G3 Monitors: Dell SG2716DG +  2x Dell U2515H
Freenas specs:
CPU: Intel Xeon E5-2650 V2 Cooler: Some noctua cooler Motherboard: Supermicro X9 SRL-F RAM: 8 * 8GB Samsung DDR3 ECC Storage: 6 * 4TB Seagate 7200 RPM RAIDZ2 Controller: LSI H220 Case: Phanteks Enthoo Pro PSU: EVGA 650w G3
Phone: iPhone 6S 32 GB Space Grey
https://linustechtips.com/topic/944755-iphone-6s-charging-speed/
From experience it is going to be slower.
Why are you grabbing an Iphone 6s and not like a Nokia 6.1/6 or Nokia 7 pluss? Its more value for money
Also check if it is USB 3.1 which can deliver 5 amps. Not that it matters as i think the Iphones dont support fast charging untill like the newest models
I got a good deal on the 6s and my carrier doesn't have much aside from Apple so a Nokia phone isn't an option (they have maybe 6 or 7 android phones total). I do have a USB 3.1 type A and a usb c port as well on my motherboard but you're correct that the 6s doesn't have fast charging.
PC Specs:
Freenas specs:
