Hi
I have an Acer aspire e5 575g 58uj and in desiring more for gaming performance and my laptop doesn't have thunderbolt or a removable GPU, so then I looked at products [this] that take the mPCI-E slot from your laptop and then give you a full-size PCI-E slot for a graphics card and I had a few questions.
1. what is a good graphics card to pick, I was thinking about the EVGA GTX 1050 gaming (i just want to do Forza and Fortnite really)
2. are these legit, do they work as advertised and is it safe to run a GPU that takes all power from the PCI-E slot that is powered by the laptops SATA power connector?
3. I have an i5 6200u and 8gb ram, will any of those be severe bottlenecks that hinder performance (planning to add another 8gb of ram anyway. 16gb total)
4. [this] is the eGPU I was looking at and it says that it is for mining but also says that it can be used for eGPU purposes, is this true? can this be used for gaming?
READ: I am a kid and don't really have a big budget and my parents won't allow me to get a new laptop for many years so I would like a setup that won break the bank but will stay suitable for years to come
Seriously any help would be appreciated.
https://linustechtips.com/topic/944717-laptop-egpu-setup-help/
These are really janky, have essentially no official support and require an external PSU.
Here is something I found with a quick search on YouTube
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/944717-laptop-egpu-setup-help/#findComment-11506705
I am aware that these are pretty janky but its really the only thing that i can do right now. also the card that i was going to use (evga gtx 1050) dosent require external power which should allow me to purely run of the laptops sata connector, which was another question i had was is it safe to run the card and draw like 75 watts from a single sata power cable
https://linustechtips.com/topic/944717-laptop-egpu-setup-help/#findComment-11506717
I don't believe mPCIE can deliver enough power for a GPU. In the video he uses the PSU to power both the adapter and the card.
https://linustechtips.com/topic/944717-laptop-egpu-setup-help/#findComment-11506725
yea i thought that there might be an issue with power the egpu thing also taps into the laptop sata power for power but the card im using dosent have power plugs on the top and this mining edition epgu thing dosent support an external psu on the side of it so i believe that all the power comes from sata and all the data goes thru mpcie
https://linustechtips.com/topic/944717-laptop-egpu-setup-help/#findComment-11506734
