HI
i need help quick!
I installed win7 on my friends machine and now the wifi usb doesent work anymore, its not even detected.. it works on my computer but not on his...
The drivers are updated to the latest version but i havent yet updated the windows..
WHAT CAN I DO???
specs:
oem core 2 duo E7500
gtx 220 1GB
Gigabyte MoBo
4GB of generic DDR2 RAM
and you know the sound windows makes when you plug in a usb device, when i plug in the wifi adapter it does it in a much shorter and lower variation
like taa-dm when its ok, but all it does now is t-dm.
RIG-Processor: Intel core i7 3770k @4.4GHz,Mobo: MSI Z77-G43,GPU:Gigabyte GTX 770, RAM:16 GB G-skill sniper f3,SSD: Corsair Force f3 240gb,HDD: Seagate baracuda 1TB,Cooler:CM Hyper 212 evo, Case: Sharkoon T28 Blue
Peripherals- Monitor: Samsung S24B300, Keyboard: Razer Blackwidow, Mouse: Razer Abyssus, Headphones: Razer Megalodon, Mousepad: Razer Goliathus Alpha, Webcam: Logitech C270,Pad:Logitech F710, Sp: Philips generic ones
#KILLEDMYWIFE #MAKEBOMBS
https://linustechtips.com/topic/94461-usb-wifi/
What brand model is it? It probably has a driver you need to install for it that you forgot.
I tried with 2, one is a level 1 E0605, the other one is a linksys AE1200
they both work on my computer without any drivers, just plug in play
AAAND the system is a Win7 Premium 64bit from dreamspark
https://linustechtips.com/topic/94461-usb-wifi/#findComment-1266910
i doesent even detect it like a working device
https://linustechtips.com/topic/94461-usb-wifi/#findComment-1266981
