hi guys
i have mobo have only 3 pin sys-fan and i want to install more fan on this pc
i will buy fan controller but i dont know if it will work this need 4 pin connector i think and sata cable to connect it to pc and my mobo only have one 3 pin
this fan controller i will buy :
NOCTUA NA-FC1
or get this fan with fan contriller :
XCLIO 256 COLOUR LED QUIET FAN 120MM WITH SMART CONTROLLER
or :
CORSAIR SP120 RGB LED HIGH PERFORMANCE 120MM FAN WITH CONTROLLER i think it come with fan controller i don't know
last one i can get :
ASETEK FAN CONTROLLER KIT
those fan controllers cheap on my country
but there is expinsive one too like this one for 50-55$
NZXT SENTRY MESH FAN CONTROLLER 5CH 30W
on znxt website price for 25$ so double the price on my counry
i want something work and cheap to get 2-3 fans work on those fan connectors
what should i get ?? like i said my mobo only have 3 pin connector for case fan
https://linustechtips.com/topic/944476-fan-controller/
It does, yes. I can confirm since I have 3 of these Corsair SP120 fans. There's a fan controller and also a fan hub to connect all of the RGB goodness.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/944476-fan-controller/#findComment-11504559
1 minute ago, leaderra3d said:
sorry for late replay
if it does how can i install it on my pc ?
There's no software for it. (At least to my knowledge)
All of the lighting is controlled through the physical controller and fan hub.
https://linustechtips.com/topic/944476-fan-controller/#findComment-11504802
i don't mean install any software
i mean install this fan controller on 3 pin fan mobo
i will explain this for you my mobo only have 1 3 pin sys fan there is no more than one
so how to put 3 fans on one 3 pin sys-fan with the fan controller ??
https://linustechtips.com/topic/944476-fan-controller/#findComment-11504851
Most controllers don't connect to mobo. The point of them is that you use knobs, touchscreens or remotes to set fans to speeds you like. They get power directly from PSU.
You could just get 3-way 3pin splitter. This would mean that all 3 fan will run at same speed. But otherwise its all good as headers can power up to 4 fans (depends on fan specs).
Controllers that hook to mobo use USB as interface and software for setting speeds. If you want BIOS or motherboard software to control things, we would be talking about hub. Hub is kinda like splitter, but has external power. There are two kinds. One without any speed controls (3pin with external power) and one with PWM based controls (uses PWM header on mobo). Most PWM hubs require fans to be PWM too to get best out of them. But there's at least one model which converts PWM signal to voltage control for 3pin fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/944476-fan-controller/#findComment-11505710
