So I just finished building my ryzen 5 2400g pc and it's acting poorly. Even though it works, it's not that good. When pulling up the home menu on Windows 10, it stutters. Even Minecraft has horrible frame rate issues. Is it something with the drivers, my bios? I just need help fixing it.
https://linustechtips.com/topic/944367-frame-stutters-everywhere/
Are you using a dedicated gpu or the vega from your 2400g? If your using it from the chip itself there is an option in bios where you can assign memory to it. Select max value there and see if it is better. These chips share memory of your ram. By default it's set to 512mb. Set it to 2gb which is the max.
