6 minutes ago, clevernation126 said:
xmp is an intel feature but does xmp profiles work on amd?
sorry, LOL did not see that you had a Ryzen build :P
XMP is indeed an Intel feature, but the last couple of years more and more the AMD motherboard makers are simply moving to XMP as it's an industry standard and much easier to keep up in the BIOS than other methods.
If you have an ASUS board, you might see something like DOCP (Direct Over Clock Profile) and EOCP (Extended Over Clock Profiles) is GigaBYtes version of the Asus DOCP.
https://linustechtips.com/topic/944093-trident-z-rgb/#findComment-11501056
Ryzen is known to have memory issues. Possible you just got unlucky
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/944093-trident-z-rgb/#findComment-11501060
I tried DOCP but it booted with 2133mhz instead of anything close to my memory's rated speeds, I could only get up to 2400mhz:(
https://linustechtips.com/topic/944093-trident-z-rgb/#findComment-11501852
