I am moving to a new apartment that have hard wired in my pc is not an option. So i need some recommendations for wifi card, i prefer a pcie wifi card. I do mostly online gaming and watch Netflix on my pc so speed is important to me
Any recommendation?
Thank you i appreciate any help
https://linustechtips.com/topic/944084-wifi-card/
I would get any PCI-E to wifi card adapter with an AC 8265, I was able to achieve 180mbs in my 200 mbs internet. I bet you can find newer intel AC cards.
CPU: Intel - Core i7-8700K @4.9 GHz 6-Core Processor CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU CoolerMotherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4 @3000 MemoryStorage: 960 evo 500gbVideo Card:place holderCase: Phanteks - Enthoo EVOLV ITX TG (Black) Mini ITX Desktop Case Power Supply:SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply Case Fan: be quiet! - SilentWings 3 pwm 59.5 CFM  140mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor Mouse: Place holder Sony H.ear on Wireless Noise Cancelling Headphone, Charcoal Black (MDR100ABN/B)  LEOBOG K26 Wired RGB Mechanical Keyboard,Gaming Keyboard,RGB Color Backlight,104 Key,Anti-Ghosting For Full Key,Blue Switches,Aluminum Chassis,Detachable wrist rest,PC,Computer, Laptop,BLACK (Black)EZDIY-FAB Sleeved Cable - Cable extension for power supply with extra-sleeved 24 PIN 8PIN 6PIN 4+4 PIN With COMBS- Black Grey
pcpartpicker: https://pcpartpicker.com/user/resdal42/saved/sCW6XL
https://linustechtips.com/topic/944084-wifi-card/#findComment-11501618
Do you get higher rates on wired?  180 is a bit low for a 2x2 AC client although it depends on a lot of factors.
PC : 3600 · Crosshair VI WiFi · 2x16GB RGB 3200 · 1080Ti SC2 · 1TB WD SN750 · EVGA 1600G2 · Define C
https://linustechtips.com/topic/944084-wifi-card/#findComment-11503252
i get my full 200 wired. i just use the wifi on my laptop that has that chip
https://linustechtips.com/topic/944084-wifi-card/#findComment-11503260
Its been my experience WiFi on PCs can be a bit funny about hitting full broadband speed, even when WiFi to LAN speeds are much much higher.  Not sure why to be honest, I assume its just the nature of slapping so many different network transport technologies onto each other, the latencies add up.
https://linustechtips.com/topic/944084-wifi-card/#findComment-11503393
Like all these radio frequency technologies, it really depends on a lot of factors you just can't know without trying.
If your house wiring is good and its a relatively short distance on the same breaker/circuit as the router then typically yes a good powerline adapter should work well, but the only way to know for sure is to try it.
WiFi is generally cheaper to try, although stick to known brand adapters as the cheaper unknown/unbranded ones even using identical chipsets often have poor antennas/amplifiers so their range and speed is much worse.  I found that out while out of curiosity buying two identical chipset adapters, one TP-Link, one unbranded off eBay.
https://linustechtips.com/topic/944084-wifi-card/#findComment-11512578
10 hours ago, Moonlight warlock said:
My router is the basic one i got with my ISP aka Xfinity. I was also looking into powerline extenders , you think be better than a wifi card ?
Power line adapters if they work generally are more stable then fast. You might get slower speeds, but over all have a more constantly stable connection.
Xfinity has an assortment of Gateways they give out. Some of the newer ones support 802.11 AC, so they should be okish. The big thing you need to figure out is what WiFi standard does the Xfinity box support. Then you can decide on a wireless adapter. Though Id go with ASUS or TPLink as they seem to have good adapters.
https://linustechtips.com/topic/944084-wifi-card/#findComment-11513565
Though it should be safe to go for at least an 802.11ac 2x2 MIMO adapter, even if your router doesn't support it right now.  Saves the hassle of replacing the dongle again later.
https://linustechtips.com/topic/944084-wifi-card/#findComment-11513905
