3 minutes ago, Chanas said:
So my 1070 is really really laggy in game like gta v i have like 40-50 fps medium graphics, Is it because of my cpu i have a i5 7500 ?
If you guys have an suggestions or tips let me know. Btw i have bad fps in most games so its not like its gta v
What resolution are you running your games at? FWI an i5 7500 is a good CPU its,
not the problem.
https://linustechtips.com/topic/944025-low-fps-with-1070/#findComment-11500491
2 hours ago, Chanas said:
Gpu usage is not much ingame my res is 1440x900 i have 16 gb of ram and my grass is on ultra which might be the case. And i havent done any overclocking.
lower grass to high and turn off all the advanced settings...and see how it goes from there.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/944025-low-fps-with-1070/#findComment-11501680
