so i am trying to make an FTP server using CompleteFTP manager and filezilla as a client, i want someone in an entire different state to connect to it to exchange files, but i keep getting this error
Status:    Disconnected from server
Status:    Connecting to (IP ADDRESS) ...
Status:    Connection established, waiting for welcome message...
Status:    Insecure server, it does not support FTP over TLS.
Command:    USER : #####
Response:    331 User name okay, need password for USER.
Command:    PASS *********
Response:    530 Authentication failed.
Error:    Critical error: Could not connect to server
what do i do to fix this
MF UH BEANS
https://linustechtips.com/topic/943754-ftp-help/
I would look in the errors guide to find what the 530 based error is, it disconnects you from the server automatically most likely due to there being a wrong password inserted or another issue such as the configuration not allowing for the FTP to be executed in certain situations/instances such as over a certain encryption protocol.
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/943754-ftp-help/#findComment-11498172
it says over tls not allowed, how would i change this
MF UH BEANS
https://linustechtips.com/topic/943754-ftp-help/#findComment-11498201
What the goal is to allow TLS over the file transfer protocol via enabling it in CompleteFTP Manager.
I would recommend using the video attached within this post as I think that it does an outstanding and precise job of explaining how to enable TLS.
Hope that this helps - @Boomwebsearch
        @Boomwebsearch
https://linustechtips.com/topic/943754-ftp-help/#findComment-11498331
If you're using filezilla or other clients i've had the same problem when i did not manually set the connection type to FTP only.
https://linustechtips.com/topic/943754-ftp-help/#findComment-11498746
