I'm planning to shove an entire mITX system into an old Xbox One case, and cant fit a full PSU inside. I remember Linus used a fully external one in his "cheapest case on the market" build, but I can't find anything similar. Any suggestions? I plan to drive something like a 1060 6GB, so it also needs those connectors. Sata isn't necessary as I have an M.2 already. 300 watts would be good, but 275 watts would do, and is the lowest I feel comfortable going.
https://linustechtips.com/topic/943129-going-super-small/
This is the only one I can find that should work for your use case:
https://www.hdplex.com/hdplex-400w-hi-fi-dc-atx-power-supply-16v-24v-wide-range-voltage-input.html
PS, you also need an AC adapter to run this, one of these should work fine:
https://www.hdplex.com/hdplex-internal-400w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html
http://a.co/ch5hb8U
Here's a video showing the HDPlex in conjunction with Dell's 330w ac adapter linked above:
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
https://linustechtips.com/topic/943129-going-super-small/#findComment-11492632
