Hallo, I want to upgrade my computer I'm thinking about a CPU & motherboard bundle I don't know much about this stuff so I would like to get some help & recommendations
I have a 6 year old PC with i5 2400
256 ssd
8gb ram
I will use it mainly for audio editing with audio interface that requires thunderbolt connection
thank you
https://linustechtips.com/topic/943060-pc-uprade-advice/
256 ssd
8gb ram
thank you
Budget?
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
https://linustechtips.com/topic/943060-pc-uprade-advice/#findComment-11491920
500-600 $
Ok I'll see what I can do. Do you do any gaming/video related things alongside your audio projects?
https://linustechtips.com/topic/943060-pc-uprade-advice/#findComment-11491943
CPU: AMD - Ryzen 5 2400G 3.6GHz Quad-Core Processor  ($159.00 @ Amazon)
Motherboard: Gigabyte - GA-AB350N-Gaming WIFI (rev. 1.0) Mini ITX AM4 Motherboard  ($109.99 @ Walmart)
Memory: Patriot - Viper 4 16GB (2 x 8GB) DDR4-3000 Memory  ($164.99 @ Amazon)
Storage: ADATA - XPG SX6000 256GB M.2-2280 Solid State Drive  ($64.99 @ Amazon)
Case: Cooler Master - Elite 130 Mini ITX Tower Case  ($44.14 @ Amazon)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($46.99 @ Amazon)
Sound Card: Asus - Xonar DGX 24-bit 96 KHz Sound Card  ($39.08 @ Amazon)
Total: $629.18
Generated by PCPartPicker 2018-06-30 17:43 EDT-0400
Here's a good option for AMD, I'll try an intel based option now. The 2400G comes with a cooler btw.
https://linustechtips.com/topic/943060-pc-uprade-advice/#findComment-11491966
8 minutes ago, yohay said:
thank you very much!  I was thinking investing my money only on the cpu & motherboard if that is possible...
No point, that 2nd gen i5 runs on a completely different socket to anything 4th gen and above (4th gen up to pre skylake  use socket 1150, anything that's skylake and after uses socket 1151, though in coffee lake we saw a second revision of socket 1151 featuring a slightly different pinout) and DDR3 RAM wouldn't work in a modern system. But you're welcome :)
https://linustechtips.com/topic/943060-pc-uprade-advice/#findComment-11491990
Alright here's the intel option, the CPU comes with a cooler.
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  ($118.00 @ Amazon)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  ($68.09 @ Amazon)
Memory: Patriot - Viper 4 8GB (2 x 4GB) DDR4-3000 Memory  ($89.99 @ Amazon)
Storage: Seagate - FireCuda 2TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($99.99 @ Amazon)
Case: Thermaltake - Core V21 MicroATX Mini Tower Case  ($59.93 @ Amazon)
Total: $587.06
Generated by PCPartPicker 2018-06-30 17:51 EDT-0400
https://linustechtips.com/topic/943060-pc-uprade-advice/#findComment-11491997
Squeezed in an i5 with the intel option but it goes slightly over budget:
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.99 @ Amazon)
Total: $648.05
https://linustechtips.com/topic/943060-pc-uprade-advice/#findComment-11492001
thanks buddy!
You're welcome :) Now the only legwork you have to do is choose the build you wanna go for :P
https://linustechtips.com/topic/943060-pc-uprade-advice/#findComment-11492014
