Assuming there's a nice heatsink under that shroud, attaching some fans to it shouldn't be that big of an issue. I believe linus showed it can be done in about half an hour with some zip-ties.
If you're feeling frisky, check out my topic that Cristophe mentioned above.
If none of those are viable options, the NZXT G12 should work fine, as was also mentioned.
Godspeed!
Main Rig:
To be upgraded...
CPU: i7 6700k @ 4.8 Ghz
COOLER: NZXT Kraken x61
GPU: Asus Strix 980ti
M.2: Samsung 960 evo 500gb
SSD: Samsung 850 evo 250gb
HDD: WD Black 3tb
PSU: Corsair RM1000
CASE: NZXT H440
HTPC:
Put together for about the equivalent of 200$
Will make a custom case buildlog when time allows.
CPU: i5 2320 @ 3.0 Ghz
COOLER: Noctua L9i
GPU: EVGA 950 SC
HDD: 2x WD Green 1tb
PSU: Some old noname shitbox
CASE: Some old HP shitbox
https://linustechtips.com/topic/942994-help/#findComment-11491790
