i used to have a gt 610 and i upgraded to an HD 7850 1gb and in all games like The Crew , CS:GO , WatchDogs . I get low Fps with a Low Usage ?
any Solution ?
Infos :
Driver Num : 22.19.171.1024 / win 8.1 64bit / Jul 4 ,2017
Win 8.1 64 bit = with Max Preformance
Saphire HD 7850 1gb
Specs are :
OEM HP PC with
Q9400 2.66 GHZ (no-@)
4gb of RAM DDR2 ( 1*4)
HD7850 1gb
600w PSU (no +80/ chinesse i think)
Edited by MA_Anass
https://linustechtips.com/topic/942271-hd-7850-low-usage/
What's your CPU?
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/942271-hd-7850-low-usage/#findComment-11484482
7 minutes ago, ZeouLs said:
Believe me budy your biggest issue is RAM, not your CPU not your GPU but RAM, you need way more RAM. I'm amazed how your OS even boots
Yeah 4gb is crazy for us, but for most people just fine. But a bunch of prebuilt non-gaming PC's, laptops, and win10 tablets have 4gb ram. 8GB Minimum would be too far a stretch for OEM's imo.
Specs:
 Gaming PC: i5 3570, 16GB 1600MHz, GTX 780 3GB, Transcend 128GB, WD 500GB, Seagate 500GB, Thermaltake 600W Smart, S340 w/ RGB, Windows 10 Pro
 Server: Xeon E5 2650, 12GB 1600MHz ECC, 8400GS, WD 2TB + 1TB + 1TB, EVGA 500B 500W, Windows 10 Pro
 Laptop: Macbook Pro Retina 2013, i7 4558U, 8GB 1600MHz, Intel Iris Pro 1.5GB, Apple 256GB NVME, Mojave
 Internet: $70/month For 500/100, Actually get 525/102
https://linustechtips.com/topic/942271-hd-7850-low-usage/#findComment-11484519
12 minutes ago, ZeouLs said:
Can someone help me out. Doesnt Win10 require at least 8 Gigs of Ram to even be installed? Am I wrong?
@MA_Anass you need more ram before anything else buddy
no it doesn't require 8gigs lul, compute sticks have 1gb and they run fine
https://linustechtips.com/topic/942271-hd-7850-low-usage/#findComment-11484521
Now I feel bad for having 32 Gigs in my workstation ._.
https://linustechtips.com/topic/942271-hd-7850-low-usage/#findComment-11484528
15 minutes ago, MA_Anass said:
ik but it's ddr2
hard to find a 2GB stick
Btw Nvidia had N.experience
how about AMD ? Is there any software to check my Drivers ?
Where are you located? I found 4 sticks of 2GB 800Mhz (8GB total) on eBay for cheap.
Specs:
https://linustechtips.com/topic/942271-hd-7850-low-usage/#findComment-11484543
Im not sure where someone assumed that he was running Windows 10, but in his first post he clearly states he is running 8.1 64-Bit, and according to Microsoft, he has enough to run things just fine.  He may still need some ram, but as far as minimum specs, he has that covered.
System requirements
Applies to: Windows 8.1
Windows 8.1
  • Processor. 1 gigahertz (GHz)* or faster with support for PAE, NX, and SSE2
  • RAM. 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space. 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card. Microsoft DirectX 9 graphics device with WDDM driver
R7 5800x -:- Asus ROG Strix X570-F Gaming -:- EVGA FTW3 Ultra RTX3080 -:- EVGA 850 GA -:- 32GB G.Skill TridentZ Neo  -:- Asus TUF GT501
https://linustechtips.com/topic/942271-hd-7850-low-usage/#findComment-11484566
