Hey guys,
So I plugged a 3 pin D-RGB strip into a 4 pin RGB extension cable (which went into my motherboard 12v rgb header) as I thought it might be compatible with just using the first 3 pins and leaving one unused. It fitted perfectly fine.
I didn't work. No lighting from RGB strip. So, now I am going to get a 4 pin strip and try again.
I wouldn't have damaged anything by making this mistake would I? Anyone clever can help!
Thanks,
https://linustechtips.com/topic/941216-asus-rgb-issue/
probably didn't damage anything. I have a faulty RGB strip in one of my new graphics card water blocks that causes an electric arc and kills the whole RGB header when plugged in and everything still works fine as soon as I unplug it.
HEDT: i9 10980XE @ 4.9 gHz, 64GB @ 3600mHz CL14 G.Skill Trident-Z DDR4, 2x Nvidia Titan RTX NVLink SLI, Corsair AX1600i, Samsung 960 Pro 2TB OS/apps, Samsung 850 EVO 4TB media, LG 38GL950G-B monitor, Drop CTRL keyboard, Decus Respec mouse
Laptop: Razer Blade Pro 2019 9750H model, 32GB @ 3200mHz CL18 G.Skill Ripjaws DDR4, 2x Samsung 960 Pro 1TB RAID0, repasted with Thermal Grizzly Kryonaut
Gaming Rig: i9 9900ks @ 5.2ghz, 32GB @ 4000mHz CL17 G.Skill Trident-Z DDR4, EVGA RTX 2080 Ti Kingpin, Corsair HX1200, Samsung 970 EVO Plus 2TB, Asus PG348Q monitor, Corsair K70 LUX RGB keyboard, Corsair Ironclaw mouse
HTPC: i7 7700 (delidded + LM), 16GB @ 2666mHz CL15 Corsair Vengeance LPX DDR4, MSI Geforce GTX 1070 Gaming X, Corsair SFX 600, Samsung 850 Pro 512gb, Samsung Q55R TV, Filco Majestouch Convertible 2 TKL keyboard, Logitech G403 wireless mouse
https://linustechtips.com/topic/941216-asus-rgb-issue/#findComment-11474915
