yep. i use 4 Corsair fans with a fan controller from thermaltake. works fine. just make sure the fan controller you're buying has the correct connectors on it for your fans.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/940558-fan-hub/#findComment-11468751
Yes, fans have standard headers. Fans are either PWM (4pin) or DC (3pin). Hub would need to match with headers, otherwise they might not be physically compatible.
If fan has separed RGB control/power connector, that needs its own thing.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/940558-fan-hub/#findComment-11471016
