8 minutes ago, eblood1 said:
Yup. the card works on the PQ5 but not on the optiplex :( it shows that it dont detected on bios. but the gtx 570 works on the optiplex i dont get it :(
can you send me a link to the spec sheet of the system, it could be that the motherboard doesn't support the kepler architecture.
https://linustechtips.com/topic/940477-why-wont-work/#findComment-11468250
