Hi guys,
Im in the process of finalising my dream-come-true rig, and before the first power on would really appreciate if you could help me with a few answers. I've researched heavily and there are so many crap replies to countless threads that I am somewhat lost.
I'm not a super noob at computers, but the last time i built a rig was about 8 years ago, so a few things have changed since..
So the current setup is :
Tower - Corsair 780t
PSU - Corsair HX1000i
Mobo - Asus Maximus X Formula
CPU - 8700k
Cooling - H115i Pro
Video - Asus Strix 1080Ti OC
RAM - Corsair Vengeance 2x16 3200mhz
First of all, holy cow I was overwhelmed by the amount of cables and wires..
and the amount of manuals..
So here goes:
1) When attaching the H115i sink, i think i just barely left a tiny touch of thermalpaste before securing the sink. Sort of a gentle touch and lift motion. I guess its a no big issue and the temperatures will show me if i need to replace the paste?
2) The H115i connections... not really clear, and even my mobo manual was complete garbage in that regards. What I've done is mount the radiator on top and have the two fans below it acting as exhaust from the case. I have wired the 2 fans to the pump fan connectors. I have wired the pump 3-pin connector to the CPU_FAN (which is 4 pins, but i guess thats the point). The USB cable I figured to use a mini usb-USB and wired to my back IO as a normal USB device (hope that works?). Lastly, the SATA Power cable i've connected to the PSU SATA&Peripherals cable.
3) Is my understanding correct, that the 6+2 PCIE and 4x4 CPU ports at the PSU have the same line, its just the cables are different? Mine are all labeled Type-3, and I've stuck the CPU in the top right socket, with the other end of the cable labeled CPU into the mobo.
4) did the same as above for the most nearby 2 sockets and stuck the other end of the cables labeled PCIE into the GPU
5) Connected the 780T front panel everything, except that the molex cable had only 2 pins? Connected that to the PSU via SATA&Peripherals molex female cable.
The front panel also came with 5 fan connectors, so instead of plugging them into the mobo i plugged them in there (the 2 front fans and my 1 bottom fan).
6) Installed the PSU fan downwards, hope thats fine as well.
Everything else seems to be OK, except i can barely close the back of the case due to the horrid amount of cabling going on there (have many drives and ssd).
Is there anything I should look into before powering on? Spent a good 6 hours so far and my back is killing me :)
I apologize in advance for the long post and appreciate any help!
https://linustechtips.com/topic/940373-need-help-with-connections/
Yeah the cables for the cpu and pci should use the same port on this psu and just different cables so that's good. Some mobos will have a 4 pin "pump" header that is labeled as so, but my general understanding is that fan and pump headers are really the same at least for aio liquid coolers. Everything else on here looks fine as well, the thermal paste should be fine but like you said thermals will tell you that. I would suggest using the program speccy for thermals as it shows the thermals for just about every component and I like it a lot for that reason. The only thing left to do is power her up and see if she posts. Its a fine looking build hope everything works straight away.
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Redshift)
CPU: Ryzen 7 9800X3DX MOBO: MSI MAG X870E Tomahawk WIFI RAM: G.Skill Flare X5 (2x16gb) 6000MT/s 28-36-36-96 GPU: Sapphire NITRO+ 9070XT, Cooler: Noctua NH-D15 Chromax Storage:  Intel S3520 150gb x4 RAID0 for boot, Crucial P310 4tb x2 RAID0, MSI Spatium M470 1tb, SK Hynix Platinum P41 2tb,  Case: Phanteks Evolv X2 PSU: Seasonic Foucs GX 850W OS: Windows 11 Pro 64 bit
HexOS Server (Vault)
CPU: Xeon E5-2603v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000MT/s 16-18-18-38 GPU: Headless Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 150gb x2 for boot RAID1, x16 in RAIDZ1 for storage, LSI 9305-16i HBA,  Case: Phanteks Enthoo Pro Tempered Glass PSU: EVGA SupeNOVA G1+ 750W
