When I made my loop I never took into account how I’d measure the coolant temperature. The only temperature sensors I’ve seen out there are fittings with a sensor built into it. It’s kind of too late to get a fitting like that since my loop is completed. Is there any other way I could check my temps without having to disassemble the loop?
https://linustechtips.com/topic/940113-checking-coolant-temps/
3 minutes ago, Leinad4400 said:
Thermal camera? Aside from that you'd probably have to take it apart to install a thermistor or a sensor fitting.
I have an infrared thermometer but I don’t know how accurate it really is. Maybe I could open one of the caps on the top of my reservoir and point it at the liquid inside. If that doesn’t work, oh well, at least I learned something for next time
https://linustechtips.com/topic/940113-checking-coolant-temps/#findComment-11465097
Don’t see you’re ovet concerned about it.
If you installed a drain plug with a valve, put it there and open it and wait for it to normalize the dead zone. Would work well enough. I could prolly buy another one tomorrow and test that out.
https://linustechtips.com/topic/940113-checking-coolant-temps/#findComment-11465320
I'm not concerned, I'm just curious lol.
https://linustechtips.com/topic/940113-checking-coolant-temps/#findComment-11466962
You can get film thermistors and directly have it in the fins of the rads, I've done that before and it gives reasonable readings, the most accurate would be a direct fluid contact probe or stopper.
Image result for thermistor film
https://linustechtips.com/topic/940113-checking-coolant-temps/#findComment-11468132
