Basic Help Needed For a Noob - RAM ISSUES
Solved by Jtalk4456,
first off, get a can of compressed air and clean it out a bit, second you should be able to get a ddr2 2gb stick to replace the 1 gb stick. I actually just did the same thing for a coworkers computer, though he had bad ram, not a bad slot, so i just found a 2x2gb set for so cheap there wasn't any point searching for a 2x1gb set
Also
for comparison, though unless you need that much I wouldn't bother
