This is the beginning of my system upgrades for 2014. first im adding a Gtx 760.
post-45946-0-55656400-1388135024_thumb.j
Im also adding some new ram, 8GB of corsair vengace.
post-45946-0-40262000-1388135073_thumb.j
I have an old 9800GT, would using this as a dedicated PhysX card be worth it?
post-45946-0-07060000-1388133886_thumb.j
the specs of the new system will be:
CPU: Core i5 3330
RAM: 8GB Corsair Vengance
GPU: NVIDIA Gtx 760
Motherboard: Intel DP67BGB3
Case: Corsair Carbide 300R
PSU: Looking into a corsair HX or RM series.
more to come.
https://linustechtips.com/topic/93919-upgrading-my-system/
dedicated Physx meh... Unless the physx card is good you will notice performance decrease instead also so few games use it and a 760 should be fine. So I am leaning towards no.
thats kinda what i was thinking, just wanted a second opinion, thanks. what do i do with an old 9800?
https://linustechtips.com/topic/93919-upgrading-my-system/#findComment-1260795
coaster for drinks like logan ^_^
CPU: i5 4670k with Noctua C12P-SE14 GPU: Gigabyte GTX 770 SSD: 250gb Samsung EVO MOBO: MSI Z87-G43 RAM: 8GB G-Skill 1600mhz PSU: Antec HCG 620W CASE: Corsair 300R windowed
https://linustechtips.com/topic/93919-upgrading-my-system/#findComment-1260798
don`t bother with dedicated physx. for psu go with seasonic G 450W
nice build man
Thanks, the recommended PSU for the card is 500, i was mostly going for corsair in this build, with fans, ram , ssd, case, and psu, if there is a good silent one that is 750W. i will add another Gtx 760.
https://linustechtips.com/topic/93919-upgrading-my-system/#findComment-1260803
You can't go wrong with a Corsair RM750.
Corsair 900D | MSI MPower Max Z87 AC | i7-4790K @ 4.7Ghz | 1080 Ti SLI | 16GB Corsair Vengeance Pro 2400
XSPC Raystorm | EK-FC Nickel GPU block/backplate | 2x Alphacool UT60 480mm & XT45 240mm | 11x Linus Edition NF-F12
Schiit Modi/Magni 2 Uber | 5" KRK Rokit G3 | KRK 10S2 | Acer Predator X34 | Dell S2716DG
https://linustechtips.com/topic/93919-upgrading-my-system/#findComment-1260811
the reccommendation is a trash 500W . thats a seasonic gold. your pc will use MAX ~250W and LESS in games . you will be around 400W with another gtx 760 so a seasonic g 650W is more than enough.if you really want corsair buy it lol. i reccommend corsair HX over RM anyday but if you are set on RM for silence go for it. the HX 750 W holds with ease 2X gtx 780 in sli + K cpu tough so 650 is more than enough
https://linustechtips.com/topic/93919-upgrading-my-system/#findComment-1260823
ok thanks. :)
https://linustechtips.com/topic/93919-upgrading-my-system/#findComment-1260824
