200mm RGB fans on H500P Are STUCK ON BLUE
On 6/18/2018 at 2:30 PM, UrbanPhoenix said:Hmm... Did the case come with a manual or instructions for the RGB software?
No, It just came with case disassembly/reassembly instructions, and a warranty card
SOLOUTION: So it turns out that the headers on my motherboard are GRB instead of RGB, and i found an adapter on amazon:https://www.amazon.com/Phanteks-Adapter-Specified-Control-PH-CB_RGB4P/dp/B01BZIBJAK
Featured Topics
vortexx21 ·
Posted in General Discussion0 -
testcy ·
Posted in Storage Devices1 -
EzioWar ·
Posted in Peripherals0 -
AlexStarr ·
Lythyum ·
2
damian61 ·
Posted in Troubleshooting1 -
BrandBoozle ·
Posted in Troubleshooting4 -
1
mecurt78 ·
Posted in Troubleshooting2
