Hi Guys,
I am looking at building my first PC I am based in the UK I have a a Budget of £860 with a buffer of an extra £200.
Aims
My aim is to build a PC that I can:
1.) Work on spreadsheets, multiple, browser tabs & windows, many word and power point windows.
2.) Game on, I would like to Game at 4K and in VR in the future as I am aware that my current budget wouldn't allow me to do that. The kinds of games would be Fall out, League of legends, Far cry 2 ect.
3.) Run a Plex Sever, future once again.
Monitors
I currently have two 19 inch monitors I plan to upgrade them to three 24-inch 4K monitors or 1 ultrawide but this would be in 6 months’ time when I have the funds and done more research in what will suit my needs the best.
Peripherals
I will need windows I would prefer windows 7 but if not possible windows 10 will do. I have all other peripherals covered.
Why are you upgrading?
I am upgrading because my current workstation is 8 years old and seriously slow to boot and load windows and very poor and gaming.
·         Intel Core i3-2100 @3.1GHz
·         3 GB of RAM (unsure if DDR2 or 3)
·         Integrated graphics
·         500GB mechanical hard drive.
As an idea of what I am currently running.
Some requirements
·         I would like to run and Core i7-8700K or equivalent (no preference on Intel or AMD)
·         A case that can hold at least five 3,5-inch drives (one for games, one for plex, one for work, 2 for back up)
·         Space for a Blu ray/CD/DVD drive
·         A case that is easy for a novice to build in and cable manage
·         A Motherboard that will allow overclocking as I would like to try in the future.
·         An SSD/M.2 for a boot drive.
Extra info
·         I am not fussed on RGB (a horror I know)
·         I am not fussed on looks or colour schemes
·         I will NOT be buying the GPU now but will be soon. (I assume the motherboard/CPU will have integrated graphics.) please correct me if I am wrong, I plan on buying a 1080 or 1080ti.
Many thanks in advance for any help or support offered. I may have said something stupid or incorrect so please correct me.
If this needs any editing or more information I will edit ASAP.
Asreall
https://linustechtips.com/topic/938141-my-first-build/
Use just one ultrawide at 1440P, much better than using 3 monitors, and gets rid of excess power and HDMI cables.
Here you go.
https://pcpartpicker.com/user/itau11/saved/#view=wdW2RB
This will do great in games. If you have some money to spare, I highly recommend a 1070ti. If not, then this will do you well.
hi.
https://linustechtips.com/topic/938141-my-first-build/#findComment-11446934
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  (£257.99 @ Aria PC)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  (£64.97 @ Amazon UK)
Memory: Team - T-Force Delta RGB 16GB (2 x 8GB) DDR4-2400 Memory  (£139.99 @ Overclockers.co.uk)
Storage: Samsung - 860 Evo 250GB M.2-2280 Solid State Drive  (£65.99 @ Aria PC)
Video Card: Palit - GeForce GTX 1080 8GB Super JetStream Video Card  (£466.46 @ Amazon UK)
Case: Fractal Design - Focus G Mini (Black) MicroATX Mini Tower Case  (£38.99 @ Aria PC) just get one large HDD for everything instead of getting a bunch of them.
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£47.54 @ YoYoTech)
Total: £1081.93
Generated by PCPartPicker 2018-06-16 13:31 BST+0100
https://linustechtips.com/topic/938141-my-first-build/#findComment-11446975
Total: £1081.93
Thank you so much for the advice and help.
https://linustechtips.com/topic/938141-my-first-build/#findComment-11446980
