Hi @Nimgg,
From looking at this, I'm guessing that you are wanting a traffic light system to work?
It's quite hard to get code to work if you don't know what it's supposed to do :)
Josh
I will only ever answer to the best of my ability - there is absolutely no promises that I will be correct. Or helpful. At all.
My toaster:
CPU: Intel Core i5-4670k @ 4.3GHz
Motherboard: Asus Maximus VI Formula
RAM: 16GB Corsair Vengeance DDR3
GPU: Nvidia GeForce GTX770 2GB
Case: Some free Sharkoon case
Storage: Crucial MX500 500GB SSD | Western Digital Blue 1TB
PSU: Corsair HX750
Display(s): Acer framless 24" 1080p thing | Acer 22" 1600x900 thing
Cooling: Corsair H100i AIO | 2 x Corsair LL120 front intakes on radiator | 1 x Corsair LL120 rear exhaust
Keyboard: Steelseries Apex
Mouse: R.A.T 7
Sound: HyperX Cloud II headset | Creative EAX 5.1 speakers
OS: Windows 10 Pro
https://linustechtips.com/topic/937462-help-me-with-my-code/#findComment-11440955
5 minutes ago, Nimgg said:
@MrJoosh
yeah its a traffic ligth, with a button, im shamed of my self for not being able to make it work
I think the attached should work, but i don;t have an Arduino with me as i'm at work :)
Let me know :)
trafikklys_med_knapp_JJ.ino
My toaster:
PSU: Corsair HX750
Mouse: R.A.T 7
OS: Windows 10 Pro
https://linustechtips.com/topic/937462-help-me-with-my-code/#findComment-11440971
@MrJoosh
i still get this as an error message:
"expected primary-expression before ')' token arduino"
the error is on the Else command here:
void loop() {
  "  if (digitalRead(button) == HIGH){
        delay(15); //pause i programmet
        if (digitalRead(button) == HIGH) {
            // når du trykker ned knappen forandrer lyset seg
      // When you press the button, the light changes
      changeLights();
    } else();{
    delay(15000); // stopper i 15sek
https://linustechtips.com/topic/937462-help-me-with-my-code/#findComment-11441063
1 minute ago, Nimgg said:
@MrJoosh
void loop() {
      changeLights();
    } else();{
Sorry, mb, remove the brackets and semi-colon from the else line:
void loop() {
			changeLights();
    } else {
Josh
My toaster:
PSU: Corsair HX750
Mouse: R.A.T 7
OS: Windows 10 Pro
https://linustechtips.com/topic/937462-help-me-with-my-code/#findComment-11441066
