Fast Sync is only meant for low demanding titles that run at over 2x your monitors refresh rate. If your's is 60hz, then enable Fast Sync if you get a consistent 120+FPS.
Fast Sync gives you less peripheral latency with no screen tearing (so better than no v sync for the non competitive gamer).
For everything else either disable V Sync, run V Sync, or run Adaptive V-Sync it's a personal preference.
Ryzen 5 3600 | MSI B450 PRO CARBON AC | EVGA GeForce RTX 2060 SUPER XC ULTRA |
Cooler Master Hyper 212 EVO Black Edition | Corsair Vengeance RGB 2x8GB 3200MHz |
Phaneks Evolv Tempered Glass | Seasonic FOCUS Gold+ 750W |
Samsung 960 EVO 250GB | 860 EVO 500GB | 850 PRO 256GB | Toshiba 2TB 7200RPM
https://linustechtips.com/topic/937389-gsync-help/#findComment-11440366
24 minutes ago, TATY said:
so i got this pg348q monitor and was wondering in the nvidia control panel in mange 3d settings
do i put Vsync ON or FAST???
if you put it OFF your FPS will go higher than the max refresh of your monitor and will introduce screen tearing...i run Vsync ON and Gsync on.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/937389-gsync-help/#findComment-11440391
