i have comcast fiber speed the wierd thing i test with my older one it went to 900 close to it but i try my new system it goes half 500 and some times lowers or twice lowers is my computer doing something wrong as i dont use networking software on it and i dont mess with that or is this a motherboard flaw useing a intel  r 1211 gigabit network
old system is asus
new one msi carbon pro 370
https://linustechtips.com/topic/936831-home-network-help/
A few things you can try, reinstalling the network driver which you may have already done.
If you are using any msi software utilities like gaming lan manager, remove that reboot and retry
If you have a spare drive try loading a vanilla copy of Windows 10 and test with minimal no software installed (except if it won’t work without the driver installed do the minimum driver only).  You can create a usb 10 installer from Microsoft’s website with the free media creation tool
https://linustechtips.com/topic/936831-home-network-help/#findComment-11435943
