Threadripper cooling
Solved by WoodenMarker,
1 minute ago, AverageAfro said:Oh, I mean Putting an AIO on the GPU and going with the Noctua cooler for TR. In my head it's a lot because I'm pushing warm air directly to the cpu.
Unless the case is very cramped and doesn't have much airflow or you're running multiple GPU-cooling AIO's for intake, it wouldn't worsen cooling for the CPU that much--maybe a 1-2c rise.
