I have MLs too and they work fine. Corsair even says that they're meant for both use cases, I don't see a problem here. Besides, people don't really make specific fans for specific use cases. They might make fans that are slightly more optimized for one thing (like the MLs, they're only slightly more optimized for SP rather than AF) but most of the time, you don't notice anything and it makes no difference in temps, maybe by a degree at max.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11432430
51 minutes ago, vladonizer said:
I am looking for the best airflow optimized sound/performance fans for 120mm and 140mm I have corsair ML fans right now and feel like they are not optimized for airflow though. They can be existing fans or fans that will be launched soon.
1) are you happy with the temps
2) are you happy with the noise
3) how many fans do you need
is it worth to you solving 1 and 2 if you where to pay 20*number of fans in usd?
if so let us know.
CPU: Intel - Core i7-8700K @4.9 GHz 6-Core Processor CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU CoolerMotherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4 @3000 MemoryStorage: 960 evo 500gbVideo Card:place holderCase: Phanteks - Enthoo EVOLV ITX TG (Black) Mini ITX Desktop Case Power Supply:SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply Case Fan: be quiet! - SilentWings 3 pwm 59.5 CFM  140mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor Mouse: Place holder Sony H.ear on Wireless Noise Cancelling Headphone, Charcoal Black (MDR100ABN/B)  LEOBOG K26 Wired RGB Mechanical Keyboard,Gaming Keyboard,RGB Color Backlight,104 Key,Anti-Ghosting For Full Key,Blue Switches,Aluminum Chassis,Detachable wrist rest,PC,Computer, Laptop,BLACK (Black)EZDIY-FAB Sleeved Cable - Cable extension for power supply with extra-sleeved 24 PIN 8PIN 6PIN 4+4 PIN With COMBS- Black Grey
pcpartpicker: https://pcpartpicker.com/user/resdal42/saved/sCW6XL
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11432446
if so let us know.
Well I had just always heard noctua fans are the best for performance/noise, but wasn't 100% sure. I would be getting either 3x 120mm or 3x 140mm for the front of my new case where astetics doesn't matter and the back/top I was either going to put my ML120 fans or get corsair LL fans. I can't say on temps right now because with my current case I'm forced to put my aio with loud sp140s in the front and have 3x ml120s exhaust which keeps the air coming in my case toasty. So my new setup will have a rad(360mm) up top, a 140mm fan in the back (those will either be ML fans or ll) and then 3x fans in the front. Can either be 120s or 140s.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11432530
What are your specs and temps? Why are you not satisfied with your current cooling?
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11433213
https://pcpartpicker.com/user/Vladonizer/saved/rKQHNG
I do not like the radiator in the front, blowing hot air on all of my componants and I want positive airflow. That's why when I switch cases I want a 360mm rad on top. I am probably going to use my ml fans on the radiator, and wanted to put either 3x120s or 3x140s in the front. In this case they will be mostly hidden from sight so instead of caring about looks I just wanted to get good and quiet airflow fans
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11435941
2 hours ago, vladonizer said:
The parts list is private. You could use a standard permalink instead.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11436280
10 minutes ago, vladonizer said:
My apologies. Private is turned off now
https://pcpartpicker.com/list/8WJgw6
Air coming through a rad will be a bit warmer but not hot. It doesn't make much difference to temps and cooling for other components as long a there's adequate exhaust for the case. What you already have seems perfectly fine.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11436394
Well... Whats the best 140mm airflow fans sound/performance?
I know it works fine, I just don't personally like my setup.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11436419
It depends on what noise levels you're aiming for. At low rpm, NF-A14's would probably be the best. NF-A12x25's would be better if you can use 120mm's.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11436489
The case I'm getting can do either 120 or 140s. I'm mostly just trying to get them quieter than a ML fan from corsair
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11438200
What rpm are you running the ML's at? Are you using pwm?
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11439442
They are on pretty low rpms. I cannot hear them at all. I am just looking for a fan that's actually designed for airflow and I want to make sure that it's not louder so I won't hear it. Since I will most likely be re using these ML fans for a 360 radiator in the top and want some fans for the front to be 140mm
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11439565
The 400C has a solid panel front and a bit of static pressure is useful. ML's are pretty suitable already. How are you determining that it doesn't have enough airflow?
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11440023
I'm changing my case. ML fans are probably going to go on my new radiator(360mm) in the top of the case. New case has enough room for 3x140mm fans in the front. Since I have to get new fans for the front anyways, I wanted to get good quiet airflow fans. Hoping for something better for airflow and c a little cheaper than buying 140mm ML fans. Thought about noctua, but I know nothing about their or any companies fans besides corsairs. Wanting good airflow fans so the rpm could be lower than a fan designed for each.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11440518
What case are you changing to?
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11440649
3 hours ago, vladonizer said:
I'm planning on the Evolv X when it comes out
The Evolv X is actually more restrictive and would benefit from fans with more static pressure than the 400C.
If money isn't an issue, NF-A12x25's would probably be best.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11441958
Are the 120mm better than the 140mm version?
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11442122
There's no 140mm version of the same design out yet. The NF-A14 is older and will be superseded by what I imagine would be under a slightly different name.
3x NF-A12x25's would easily be better than 2x NF-A14's though.
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11442207
Okay, thanks a lot!
https://linustechtips.com/topic/936553-airflow-fans/#findComment-11442261
