5 minutes ago, IrishDunner said:
I'm currently doing my first build, I'm going with an i7 8700k and need some advice with what motherboard to get, I was thinking of the asus maximus x hero should I be thinking of any others
why do you want the Maximus X Hero?
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/936187-motherboard-advice/#findComment-11429085
Just now, IrishDunner said:
this is my first build so i'm a total newbie so open to any suggestion
either ASUS Z370-F or ASUS Z370-A if you don't mind the white :) Gigabyte and Asrock also has lots of great looking boards but depends on which brand you prefer, and for ASUS anything above Z370-A (including Z370-A) doesn't have much benefit other than looks, Maximus X Hero has WIFI built in, but other than that there's nothing else, it's not worth it at all to spend an extra 100$ for it.
3 minutes ago, IrishDunner said:
GIGABYTE Z370 AORUS Gaming is another option I like
jesus christ are you always looking for the most expensive motherboard? i mean if you're gonna spend 200$+ for a motherboard then any brand would work fine, just find whatever looks best for you
https://linustechtips.com/topic/936187-motherboard-advice/#findComment-11429154
the maximus wifi is only 50 more on newegg atm
https://linustechtips.com/topic/936187-motherboard-advice/#findComment-11429165
