RGB sync help
Go to solution Solved by W-L,
5 minutes ago, Carbide X said:
Is there any program that lets me control all my rgb components ? because i have a msi mobo and asus gpu
Unless the MSI software has the ability to pickup other RGB based hardware in the system it's not possible to sync different ecosystems together.
-Moved to Modding Section-
https://linustechtips.com/topic/935656-rgb-sync-help/#findComment-11425100
1 minute ago, Carbide X said:
That sucks,
Asus has their Aura SDK which allows for third parties to make software for syncing different lighting system but I don't know if that will work without an Asus motherboard.
https://www.asus.com/campaign/aura/us/SDK.html
https://linustechtips.com/topic/935656-rgb-sync-help/#findComment-11425117
