hi heroes!
i need professional help :-) with my project .
wall pc custom case 155cm x 75 cm x 20 cm
gtx 1080ti
 EVGA Hydro Copper
8700k  (water ) cuplex kryos NEXT VISION
4x 360mm radiator (for  120mm fans)
2X 240mm radiator
2x120mm radiator
3x Syscooling SC-P90 1300L/H
4x 50mm/400mm water  tank
motheboard .......just no idea ...z370 or new z390
corsair dominator platinum 64gb 3333mhz
power adapter  rgb   just no idea ....
18x rgb fans
and this ist problem ! because i need pure sync with light and speed
my favorite Aigo aurora C5  but max is 10 fans on one controller and other companies  no better solution?
thanks for every answer and idea!!!
https://linustechtips.com/topic/935246-beast-wall-pc/
11 minutes ago, LENS_PROOF said:
 nitrogen in a closed circuit?
He was joking. LN2 cooling requires a ridiculous amount of maintenance.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/935246-beast-wall-pc/#findComment-11421241
You won't get below ambient room temperature though is what I mean with Air or Liquid coolers. Your plan seems like a good way to spend money for not much gain. I am not suggesting that you use Liquid Nitrogen as it is pretty dangerous for starters, but extreme overclockers use it when going for overclocking records etc.
If it was Me I would look at buying a delid cpu and go from there. No need for all those rads though.
https://linustechtips.com/topic/935246-beast-wall-pc/#findComment-11421331
This seems overly complicated.
You might consider using just two 360 radiators, . Keep all the fans. Have all the tanks and pump housings you wish. Run the plumbing as you like, but make sure  there is only one loop. This would be substantially less expensive and will provide cooling performance as good or close to the OP proposal.
https://linustechtips.com/topic/935246-beast-wall-pc/#findComment-11421443
