Hello everyone! I'm new here and hoping to have some good time here :D
I need your thoughts on my budget part list I'm hoping to buy. I have about 950 us dollars and my needs are graphic design and digital arts (Photoshop illustrator light 3d) and light use of after effects and premiere.
I have read online and this build is the best I think for the price, please give me your opinion
Ryzen 1600
Gigabyte ga-ab350m gaming
Corsair Vengeance LPX 1x8GB DDR4 3000MHz
Gigabyte GTX 1060 Mini ITX OC 6GB GDDR5
Kingston UV500 2.5 Inch SUV500/240G
Antec 450W Active PFC VP450P PSU
Sharkoon VG4-W Black Blue
Thanks in advance!
https://linustechtips.com/topic/934254-budget-workstation-need-some-help/
I would get dual channel Ram, so 2x4 or if you can 2x8. Also Ryzen has issues with Adobe products, so keep that in mind. (Hardware Canucks and Gamers Nexus did videos on this)
yea, and invest in a HDD if budget still allows you. Maybe just to dump file if you don't have a separate storage box in your network yet.
"Make it future proof for some years at least, don't buy "only slightly better" stuff that gets outdated 1 year, that's throwing money away" @pipoawas
-Frequencies DON'T represent everything and in many cases that is true (referring to Individual CPU Clocks).
Mention me if you want to summon me sooner or later
My head on 2019 :
Note 10, S10, Samsung becomes Apple, Zen 2, 3700X, Renegade X lol
Thanks!! Which cpu alternative do you think is good for editing?
I will use HDD from my old PC or just buy after some time. Thanks man
if you consider that intel has hardware accel on premiere then maybe an i5-8400 and a B360 combo will suit you
My head on 2019 :
The r5-1600 has been superseded by the r5-2600 so it might be better to get that instead and the mx500 is a better SSD.
  • CPU
    I5-8400
  • Motherboard
    Gigabyte B360 ds3h
  • RAM
    2*8gb Vengence 2400 ddr4
  • GPU
    ASUS gtx 1060
  • Case
    Fractal define c mini windowed
  • Storage
    1tb WD blue and 240gb sandisk ssd
  • PSU
    550w bronze corsair cxm (grey)
  • Operating System
    windows 10
Well after some research I got to this article https://www.techspot.com/review/1608-core-i5-8400-vs-ryzen-5-1600-best-value/page2.html
So I will stay with the ryzen mabey I will over clock it
Where I live I having a hard time finding x470 mother board that I understood from research that it critical. I can order it from Amazon but it will take some time and the shipping is little extra money. Do you have any advice? Mabey using old mother board or something
Thank you all!!!!!
Thank you all!!!!!
ok so you can actually go for a B350 motherboard to save some bucks and i would recommend the B350-Pro 4 from ASrock,
that board will handle the Ryzen 5 1600 just fine without being hot so whichever AM4 socket motherboard you pick i suggest getting one either from Asus or Asrock
My head on 2019 :
