Hello Everyone.
So ive been having this problem for a while now, which as stated by the title, is where my mouse feels like it is almost on ice, because i dont feel in control, and there is a very slight, but noticeable delay to the movement, its not enough to stop me playing, but it certainly does make it harder to play well, like i use to (In shooters, for example)
Ive tried a good few fixes, but nothing has solved it.
I assume it is not related to my mouse itself, as the problem is present on all 4 mice that i own (My daily driver is an FK2, for reference)
Any help with this is greatly appreciated, as i get quite unsettled by problems like these, so it makes gaming quite unenjoyable, for the most part.
Thanks in advance for any and all comments :)
https://linustechtips.com/topic/933959-mouse-on-ice/
3 minutes ago, SirReggie said:
I updated my BIOS yesterday, and it didnt seem to do anything :/
Hmm, I'm stumped. It's possible that your DPI could be weird. Try going to your mouse properties and looking at the acceleration speeds.
"Kieran just stole my girl!" - No-one
Discord: Kdog#7258
https://linustechtips.com/topic/933959-mouse-on-ice/#findComment-11408055
1 minute ago, SirReggie said:
6/11
No accel
All other options disabled
Hmmm, I don't know, man. At this point, I'm pretty sure it's a software thing. A Windows reinstall may mix it but really it's up to you if you want to go that far, as it may not even work.
Discord: Kdog#7258
https://linustechtips.com/topic/933959-mouse-on-ice/#findComment-11408081
Funny you say that, ive tried that too :D
Thanks for your input tho, its very much appreciated :D
https://linustechtips.com/topic/933959-mouse-on-ice/#findComment-11408084
Your DPI settings are off. The Zowie FK2 has adjustable DPI, but I'm not sure if it's a button on the mouse (it usually is) or a software change within the drivers. I'd be willing to bet that a mystery button tap set your DPI to 3200. Check BenQ's website for drivers and a utility.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/933959-mouse-on-ice/#findComment-11408121
My DPI is 800, I dont understand how changing that makes a difference, I put it to 3200 and its the same, just faster x)
https://linustechtips.com/topic/933959-mouse-on-ice/#findComment-11408122
