I have a 2012 Chevy Cruze. I'm trying to install a single din stereo because the stock one isn't capable of playing music through Bluetooth and the volume level using the aux cable drops by like 30%. I want to keep all the vehicle radio settings etc, so I found this Scoche stereo wiring harness ( https://www.carid.com/scosche/aftermarket-radio-wiring-harness-with-oem-plug.html?make=Chevy&model=Cruze )Will this work? And then I can just install a new stereo? Or am I missing something? All help is appreciated.
https://linustechtips.com/topic/933671-car-stereo-help/
You may also need a dash kit if your current radio is double din
I recommend purchasing a stereo via Crutchfield, they provide the installation materials and instructions with all their car stereos
I have a cue light I can use to show you when I’m joking, if you like.
https://linustechtips.com/topic/933671-car-stereo-help/#findComment-11405863
Crutchfield is expensive compared to most, but it works good as a guide that's about it.
Corsair 4000D RGB
Asus B550 Tuf Gaming II
Asus 7700XT Tuf Gaming
AMD 5600x3d
32gb 3200mhz gskil
https://linustechtips.com/topic/933671-car-stereo-help/#findComment-11406075
