Hey guys,
Its going to be the first time I'm building a PC. Wouldn't mind if you looked at the parts and improved it or even gave some advice. Mostly gonna be doing gaming on it and other light tasks on it. Trying to keep it around the £800 mark.
https://uk.pcpartpicker.com/user/meerkat2808/saved/T4khqs
Any thoughts are appreciated^_^
  • CPU
    I5-8400
  • Motherboard
    Gigabyte B360 ds3h
  • RAM
    2*8gb Vengence 2400 ddr4
  • GPU
    ASUS gtx 1060
  • Case
    Fractal define c mini windowed
  • Storage
    1tb WD blue and 240gb sandisk ssd
  • PSU
    550w bronze corsair cxm (grey)
  • Operating System
    windows 10
https://linustechtips.com/topic/933585-advice-for-new-build/
You could get this Z370 board for the same price. Otherwise looks good
https://uk.pcpartpicker.com/product/V9WfrH/gigabyte-z370p-d3-atx-lga1151-motherboard-z370p-d3
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
https://linustechtips.com/topic/933585-advice-for-new-build/#findComment-11404897
Do you need the PC to be compact? If not, get an ATX case. Good ATX boards are much easier to find than good mATX boards, and you often get more room to work with.
If you switch to ATX, there's a Z370 board available for £80.
Get faster RAM. You get ~5-7% more performance with 3200MHz RAM, but there will also be benefits with 3000MHz RAM.
The A400 is a pretty bad SSD. The MX500 is the cheapest really good SSD, but you should probably be fine.
There's a Sapphire RX 580 for £10 less than the 1060 6GB. You get the same in game performance, but you get support for Freesync. A Freesync monitor is generally ~£100 less expensive than an equivalent G-sync monitor. And you can get low end monitors with support for Freesync.
For the PSU, the Formula 450W would be a better PSU, imo. Quieter and multi rail, but with a shorter warranty than the TXM (5 Vs 7 years).
https://linustechtips.com/topic/933585-advice-for-new-build/#findComment-11404927
