Need help on Newegg Return Policy
Thanks a lot
I bought an intel 4770k, A G.Skill Ripjaws RAM, Samsung SSD and a Gigabyte motherboard. Do i need to register for any of these ones?
Intel CPU: You can check warranty information here, need product on hand and will possibly need to create an account: http://www.intel.com/p/en_US/support/warranty
G.Skill RAM: This company(and many others) offer lifetime warranty for their RAM, so there isn't a warranty register for this, more information: http://www.gskill.com/en/warranty
Samsung SSD: Go to this link and create an account, you'll need the product on hand: http://www.samsung.com/us/support/register/product
Gigabyte Motherboard: Gigabyte motherboards have a 3 year warranty, bottom of this page you'll need to create an account and can check the warranty status whenyou receive the product and have the serial number on hand: http://rma.gigabyte.us and more information: http://www.gigabyte.us/support-downloads/customer-service.aspx
Again, you should read up on their warranty policies and see if they apply to people outside the U.S. These are U.S. centered links I am referring you too, so be weary of that. If a product does fail and you have the ability to send it in for RMA, try and see if you can use your forwarding service so the company doesn't deny you the warranty period. They will of course be in contact with you and will most likely send you the parts back through the forwarding service, but again, I'm no legalese, so I don't know the specifics of warranty service outside the U.S.
