1 minute ago, t4ils said:
Not sure if I'm just being blind, but I don't see one in the image :P
Some gaming monitors have a crosshair feature, maybe that's enabled for your monitor?
You aint blind haha i just clicked on it as well and didnt appear. where do you think i could find that feature?
https://linustechtips.com/topic/933525-random-green-cross-air/#findComment-11404329
On my monitor (Acer XG270HU), it's under Gaming > Aim Point. Not sure if it'll be the same for yours. Just browse around in your monitor's settings and you might find it eventually :P
https://linustechtips.com/topic/933525-random-green-cross-air/#findComment-11404336
Just found it :) thanks for the help!
https://linustechtips.com/topic/933525-random-green-cross-air/#findComment-11404350
